Downtime and recovery impact calculator
What could recovery delay cost your business?
Estimate how recovery time could affect productivity and operations, compare the result with your RTO and RPO targets, and see which recovery path is worth reviewing.
Model business impact
Estimate productivity, operating, and response impact using your own inputs.
Compare recovery targets
See the recovery-time gap and potential data-exposure gap separately.
Find the right next step
Review backup, DRaaS, availability, or Microsoft 365 recovery based on the scenario.
A backup result is only useful when the recovery plan meets the business need
Downtime impact depends on more than the size of a backup. Detection, decision-making, recovery preparation, restore or failover, validation, and business resumption all affect the result. This calculator keeps those stages visible and compares the modeled delay with the targets your business or client expects.
Use the result as a planning conversation, then validate assumptions through a documented recovery test.
Estimate your recovery impact
Enter the business impact, recovery timeline, and recovery targets for one meaningful scenario. You can model your own organization or a client environment.
Business impact
Recovery scenario
See your result
Recovery impact calculator
Before you start
  • ${ICON_CHECK} Persistent field labels and inline help throughout — nothing hidden behind icons alone.
  • ${ICON_CHECK} Every input stays editable and visible before your result is calculated — no hidden defaults.
  • ${ICON_CHECK} Takes about 3 minutes across 3 short steps.
FAQs
Is this a financial-loss forecast?
No. It is a planning estimate based on the assumptions entered. Actual losses vary and some cost categories may overlap.
RTO is the time the business can tolerate before operations resume. RPO is the maximum acceptable age of the recovery point and indicates potential data exposure.
Backup frequency affects the recovery point, not the time required to restore service. Adding it to downtime would combine two different recovery objectives.
Bandwidth can help estimate transfer time, but full recovery also includes detection, recovery start, orchestration, boot, validation, and business resumption.
Yes. Use client-approved inputs, keep the estimate disclaimer visible, and validate the technical assumptions before using the result in a proposal.
No. Microsoft 365 Backup helps recover supported data after deletion, malicious change, and other data-loss events. It does not restore the Microsoft service during a platform outage.
No. The route is a starting point based on the scenario entered. Workload support, deployment, recovery targets, and commercial fit still need validation.
Review the largest recovery gap, confirm the assumptions, and run or schedule a representative recovery test.
Ready when you are
Know the impact. Validate the recovery plan.
Use your estimate to focus the next conversation on the workload, recovery target, and test evidence that matter most.
Review your recovery plan
